Where to run Amp Ground
Old Jan 22, 2003 | 09:33 PM
Screamer27's Avatar
where is a good place to run a ground from an amp in the back of a 94 Z. I have to run the ground from my JBL 1200.1 and my cap. Where is a good place to run a ground in a Fourth gen? Also should I run the ground from the amp to the cap and then ground it, or should I ground each individually.
Old Jan 22, 2003 | 10:19 PM
atl2001's Avatar
From: carbondale IL \ Alton IL (outside St Louie MO)
look around for a bolt somewhere that will connect to the frame, undo it , srcape the paint, and ground it there. well that is what i did when i had a lil system
Old Jan 23, 2003 | 12:02 AM
PaulN64's Avatar
I did the scrape thing. but I also use a Stinger superground for mine rather than a ring terminal
Old Jan 24, 2003 | 09:42 AM
fbird95's Avatar
the antenna bracket in by the spare tire.
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
NewsBot
Jan 8, 2015 11:29 PM
PaulN64
Aug 8, 2002 05:39 AM
sleeperZ96BT
Jul 24, 2002 11:28 AM
