Where to mount amp??
Old Jul 1, 2004 | 11:12 AM
slayer6x6's Avatar
Im kinda stuck on where to mount the amp in my car. I was thinkin in the spare tire area but theres really nothing to build on back there. I would like the amp to be hidden, so I dont really want to put it right behind the back seats. Any pics or suggestions helpful. I am also putting in the stealth box on the right side.
Old Jul 1, 2004 | 03:53 PM
97FormulaWS-6's Avatar
Currently I have 2 large amps mounted on the deck.. but I'm running 5% tint on the back window and you can NOT see into the trunk area.
when I upgrade, I'm going to have 1 on the deck, and 2 on the back wall.
Depending on the size of the amp(s) the back wall is a very usefull spot that will retain t-top storage and provides more cooling room than the spare tire well; although I've seen some decent installs there as well.
Old Jul 1, 2004 | 05:11 PM
Lions3's Avatar
Actually, depending on amp size, the spare tire well is perfect. What you need to do is build a small square of MDF that will bolt on to the spot where the spare tire is mounted. Next cut to shape a sheet of MDF that will pretty much follow the countour of the floor as it goes up and over the gas tank. The sheet you cut will then screw into the square piece of MDF you attached to the spare tire mount. Carpet, attach amps, and cover with the factory plastic cover. That setup saved my amps when I got broken into.
Old Jul 1, 2004 | 11:18 PM
slayer6x6's Avatar
Lions, that doesnt sound like a bad idea. I think Ill give that a try.
Old Jul 2, 2004 | 11:10 PM
BandDirector Blk98ZM6's Avatar
Check out the link in my sig for pics and instructions on mounting amps in and behind the spare tire.
Old Jul 3, 2004 | 12:20 AM
slayer6x6's Avatar
Sweet!
Old Jul 3, 2004 | 09:25 PM
Drumhawk's Avatar
Originally posted by 97FormulaWS-6
) the back wall is a very usefull spot that will retain t-top storage and provides more cooling room than the spare tire well; .
I'm doing the same, 2 JL Audio amps on the back wall and a 10W6 sub in the cubby so I retain all my t-top space.
G-BODYT56
Jan 14, 2022 11:14 PM
alliance12364
Sep 23, 2015 12:40 PM
alliance12364
Sep 23, 2015 06:09 AM
War Engine
Sep 18, 2015 07:28 PM
Daluchman1974
Sep 11, 2015 06:12 AM
