Where is a good place to put my amp?
Got a 4 channel Alpine amp, not real big. Where is a good place to put it. Is there enough room under the front seats. Where have some of you mounted yours.
I've had one mounted under the PS seat... it was not cool...
I'm actually mounting both of mine on the back deck. I've seen them placed in the Spare-tire well before with good luck, or on the back wall of the pit with no problems.
Originally posted by LWillmann
I built an amp rack on the hump behind the rear seat. Link in sig...
Skull Leader: I run all six fans off the same relay that turns the amps on, the only noise problem I have is from all the air moving. Try running them off a seperate relay.
PaulN64: I built the amp rack myself. I build it out of 3/4" MDF and with the equipment in it it weighs plenty. The only movement I have is about 1/2 inch front to rear caused when I accelerate heavily.
It's really not that bad!
Originally posted by hotrodgirl
Mine's in the trunk. It was an easy install and doesn't interfere with storage. I have pics in my sig.
NewsBot
Jan 8, 2015 11:29 PM
Desolate_Flux
Jul 23, 2002 08:24 PM
