Where is a good place to put my amp?
Old Mar 17, 2003 | 06:25 PM
Blk94Z28LT1's Avatar
Got a 4 channel Alpine amp, not real big. Where is a good place to put it. Is there enough room under the front seats. Where have some of you mounted yours.
Old Mar 17, 2003 | 06:31 PM
rlax31's Avatar
I've seen installs in the spare tire area, I'm gonna try there when I get my amp.
Old Mar 17, 2003 | 09:15 PM
97FormulaWS-6's Avatar
I've had one mounted under the PS seat... it was not cool...
I'm actually mounting both of mine on the back deck. I've seen them placed in the Spare-tire well before with good luck, or on the back wall of the pit with no problems.
Old Mar 17, 2003 | 09:58 PM
T.O_Camaro's Avatar
In my trunk plz.....seriously do not mount on the box but on th back of the seat is a great place.
Old Mar 18, 2003 | 03:31 AM
PaulN64's Avatar
I would suggest to mount that in the trunk, or the back seat if you are willing to give that up. But I would put it in the trunk.
Old Mar 18, 2003 | 10:53 AM
BandDirector Blk98ZM6's Avatar
For pics as well as installation instructions on mounting amps in and behind the spare tire, check out the link in my sig.
Old Mar 18, 2003 | 12:25 PM
LWillmann's Avatar
I built an amp rack on the hump behind the rear seat. Link in sig...
Old Mar 18, 2003 | 12:37 PM
PaulN64's Avatar
very nice install there. I like how you put the eq under the HU. I did notice that you had a premade box for your amp rack. That would be a good idea also, but just don't plan on screwing that down.
Old Mar 18, 2003 | 01:58 PM
Skull Leader's Avatar
Question
How did you connect the fans exactly? I connected 2 fans with a relay, but they have alot of noisy interference.
Old Mar 18, 2003 | 03:25 PM
LWillmann's Avatar
Skull Leader: I run all six fans off the same relay that turns the amps on, the only noise problem I have is from all the air moving. Try running them off a seperate relay.
PaulN64: I built the amp rack myself. I build it out of 3/4" MDF and with the equipment in it it weighs plenty. The only movement I have is about 1/2 inch front to rear caused when I accelerate heavily.
It's really not that bad!
Old Mar 18, 2003 | 04:24 PM
hotrodgirl's Avatar
Mine's in the trunk. It was an easy install and doesn't interfere with storage. I have pics in my sig.
Old Mar 19, 2003 | 12:38 AM
PaulN64's Avatar
yup, that's what I had in mind to save some space for the TTops.
97TA-WS6-Con
Feb 1, 2015 01:01 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
NewsBot
Jan 8, 2015 11:29 PM
Desolate_Flux
Jul 23, 2002 08:24 PM
