Where does the alarm bump sensor go?
Old May 13, 2004 | 04:29 PM
TopleSS 01's Avatar
Question Where does the alarm bump sensor go?
I am getting ready to install my Subthump passenger side stealth box in my 2001 SS Vert & I noticed the factory alarms bump sensor is just hanging back there behind where the spare used to be.
Does anyone know where it is supposed to be mounted or does it just hang there? There should be some pocket , shelf or bracket it would snap into right?
TopleSS
Old May 21, 2004 | 10:12 PM
fredmr39's Avatar
It's mounted on the sheet metal by sticky tape-like stuff... I believe near behind the factory amp if I remember correctly... Look around there, you should see a small square where it used to be mounted... If your alarm system worked poorly before, then thats probably why...not as effective just hanging there than if it were mounted securely...
Old May 22, 2004 | 04:28 AM
LS1 RULZ's Avatar
Mine is stuck to the top of the wheel well.
14
Aug 11, 2015 12:03 PM
Noct
Jul 14, 2015 01:18 AM
asilomar244
Jul 12, 2015 05:53 AM
