Where did you guys get your high output Alernators?
Mine has been going out....need to get another high output one. I have an underdrive pulley and a 1200 watt amp, so 140 amp aint gonna do it. Right now I think its about a 180+ in there(previous owner got a bigger one, and got it jazzed up in orlando)
Someone in the LT1 section said to post it in here. Its a 95 TA.
And oh yea, for the last alternator they had to put in a different(I think bigger) accessory bracket to hold it, so i guess i need to match it to that somehow.
Thanks.
Thanks.
My car has a 140A. 140A should be fine as long as you upgrade the wiring under the hood. Add 4 gauge wires to: alternator to battery, battery to chassis ground, chassis ground to engine block.
I'd say try this first, you'll need to upgrade the wiring for a bigger alternator anyway.
I had my alternator blown up to a 200 amp it is still in the stock casing from what I understood he just put different diodes and stuff in it. I paid $225 to have it done. I have ran 3 BD1500.1 and a power 400.4 and also 3 JL 1000/1 and a JL e4300 with it.(also ran stinger spv44 and 3 farad cap with set-ups) I have had no problems with mine and have been running it for 3 years Ed Collins did mine and I would highly suggest he has a fast turn around him here is his info
Lincolnway Auto-Electric
598 Palmyra Road
Dixon, IL 61021
(815)288-2862
598 Palmyra Road
Dixon, IL 61021
(815)288-2862
Check out the Mechanical Man (mechman) Alternators. I have a link to them on my webpage. I got a chrome 200+amp alternator from them over a year ago and its running fine with no problems, especially with the punishment i subject it to, and definatly upgrade the grounds while your at it....i suggest Hyper Ground Systems grounding.....it definatly makes a diff.
themushine
Sep 3, 2002 10:01 AM
