what amp to power 3 jl 12w3d4 subs
Old Dec 23, 2002 | 09:55 PM
stik6shift98's Avatar
jbl 1200????
does jbl have gain control???????
Old Dec 24, 2002 | 12:12 AM
x7x7's Avatar
You could use the jbl 1200.1 but you would not be getting max power out of it, your load would be 2.6 ohms and that amp puts out max power at 2 ohms. So the amp would put out about 1000 to 1100W RMS.
I've never seen an amp that didn't have a gain control?
Old Dec 24, 2002 | 12:37 AM
what do u mean i wont be gettin full power out of them
the w3 handles like 250 watts each i thought
so i wouldnt be using all the amp....
or are u sayin that i wont be usin amp to full potential
Old Dec 24, 2002 | 10:30 AM
rthompson's Avatar
he meant that you wouldn't be using that amp to its fullest potential. The difference between 1000 and 1200 watts is not audible anyways, since it takes twice the power to achieve a theoretical 3 db increase, adding 20% more power will be sligghtly less than 1 db and reducing that even more are the real factors that you encounter. Non linear cms, Bl compression and power compression.
1db is considered by most as the minimum detectable change in volume, and at 140 or so db's it is unlikely that it will be at all detectable, so i say go for the JBL 1200.1 if you like or if you do think that a smidge more power would be good maybe the MTX 8100d. It is all your choice, but the little difference in power will likely not be detectable by the human ear.
Old Dec 24, 2002 | 12:05 PM
x7x7's Avatar
Yep, that's what I mean. Still like rthompson said it wouldn't be very noticable, I was just letting you know what to expect and how it will work.
Old Dec 24, 2002 | 04:37 PM
well i was wonderin if my subs can take it
jl audio 12w3d4 v1 3 of them
sleeperZ96BT
Aug 4, 2002 06:52 PM
Snake Slayer
Jul 29, 2002 12:39 PM
Vokabulis
Jul 25, 2002 05:46 AM
Zomie
Jul 21, 2002 08:03 PM
Manaz101
Jul 18, 2002 09:39 AM
