well i know what box i want help me with the speakers and amp part?
don't go q-logic, they are very crappy boxes. Talk to megabass, he is the best builder for our cars. Plus with him you will save about 150-200 bucks, b/c i think that 1-logic box is around 400 bucks.
what amp to get for the backseat speakers...these are the ones ive chosen http://www.crutchfield.com/cgi-bin/S...FC1787&o=m&a=1
Here's another place to buy the JBL BP600.1:
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=1947847407
Scala1 is a VERY VERY realiable person to deal with. Just look at that feedback rating!!!!!!!!!!!!!
I don't mean to be a d!ck, but have your already bought the kenwoods? I would really consider getting a component set. I know. I know. Too expensive, too much hastle right? Well, those were $109/pair right? There are components out there for about $120-$130/set
Kicker
http://www.cbrstereo.com/Merchant2/m...de=KICKERCOMPS
MB Quart
http://www.cbrstereo.com/Merchant2/m...gory_Code=MQCS
MTX
http://www.cbrstereo.com/Merchant2/m..._Code=MTXCOMPS
and I'm sure there are others. I'm just saying if you are already planning on spending $110 for speakers... mise well get your moneys worth. Put a set up front and a simple mid range speaker by the backseats. And as far as an amp goes..... if you are getting the JBL BP600.1 then I'd get a matching amp from JBL. But that's just me. I like having my amps match. The subs don't have to match the amps and those don't have to match the speakers, but all the amps have to match. hehehehehe Like I said, that's just me. Try the JBL P80.4
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=1947847468
Actually, a better choice might be the JBL P80.2.
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=1947867695
It's cheaper and it will give you more power. You'll have to wire your component set together (front right and left) and your backseat speakers together. This will give you a 2 ohm load. Wire the components to one channel and the rear speakers to the other!!! The only problem would be that you would not be able to fade left to right (because they are wired together) but do you really do that anyway??? Mostly front to back. Small price to pay for double the power! And cheaper....!!
Kicker
MB Quart
MTX
Firebirdude is right about kenwoods vs. components. Try to squeeze a nice pair of comps into your budget. Even if you have to go with a used set. I have some kenwood coax in the doors now and they are so limited. I bought a used set of focal polykevlars for 200 used. Can't wait to get them in.
As for the passenger box, you'll need to either trim your panel down or find a salvage panel and trim that one down and save your stock one. Too much work for me to provide them. And yes I can get 12s in the passenger box, but not the driver's side. Dual 10s will be surprisingly loud.
Well I would not get the Kenwooods for the front seats but for the back seats I would get the Kenwoods. The back seats really do not need much of a sound stage because they are so far away from you and you do not sit by them. Or better yet just don't get any back speakers at all. I know several people that run no back seat speakers and their system sounds great.
thanx alot guys youve been alot of help, this is what ive come up w/:
headunit- kenwood kdc 4019
doors- JBL GTO 635
backseat- kicker k65.2 (component set)
2 10'' steathboxes from subthump
subs- kicker compVR 10'' (2)
amps- JBL bp600.1 and JBL bp150.1
if you guys have the time can you check and make sure all this is ok, theyre all on www.ikesound.com thanx
doors- JBL GTO 635
NOOO!!! hehehehehehehe
#1 The JBL BP150.1 should not be used to power your door speakers!! It is a 1-channel amp. Meant for subwoofer use only. You need a multi-channel amp. Either of the two I sugguested will work fine.
#2 You'll want to put the components up front!!
#3 This is probably a matter of opinion but,...... I would seriously think twice about the 3-ways (JBL) for the rear. You are looking for a basic mid-range. Not co-axil or tri-axil. (Sometimes called 2-way or 3-way) You'll want to keep those very high frequencies up front. The tweeter on the co and tri-axils will destroy your soundstage. But like I said.... to each his own.
http://www.ikesound.com/Prod_Details.asp?Prod_Id=773
Check out this amp, this thing should work for your highs.
Originally posted by firebirdude
It will work fine. Puts out a lot of power and that seems to be a pretty good price. But it won't match your subwoofer amp. Which means absolutly nothing... but like I said.... I'm a **** when it comes to that!
firebirdude i was gonna use the kicker speakers that come in the component set in the backseats and the JBL 3-ways up front (along with the tweeters that come w/ the kicker set). is that a bad combo? as for that rockford fosgate amp, i would rather have amps that match too so is there a JBL amp that will suit my need?
I recommend the Kicker RMB6 ($99) in place of the kenwoods.
http://www.cbrstereo.com/Merchant2/m...ode=KICKERSUBS
And it would match your components!
And a JBL amp to match your other??? Did you read my previous post???
Try the JBL P80.4
http://cgi.ebay.com/ws/eBayISAPI.dl...item=1947847468
http://cgi.ebay.com/ws/eBayISAPI.dl...item=1947867695
okay,
Kenwood KDC-4019 (CD Reciever)
Kicker RMB6 Speakers
Kicker K62.5 Component Set
subthump “Stealthboxes” for 10’’ Subwoofers
Kicker CompVR 10’’ Subwoofers (2)
JBL BP600.1 Amplifier
JBL P80.2 Amplifier
JBL P80.2 Amplifier
