Which way is better
Old Mar 23, 2006 | 12:34 AM
eagleknight97's Avatar
Question Which way is better
Right now i have a 60watts X 4 amp powering my speakers. This summer I was going to buy another amp, a mono amp, to power the sub im putting in. Ive also decided to upgrade the front speakers from the Pioneers I have in there to some Polk Components. The sub im going to be using is an older DB Crossfire sub, which I was told would be happy with 150watts going to it. NOW, here is the dilemma. Should I buy a large mono amp, around 500watts like i was originally planning on doing OR should I buy a new 2 channel amp for my front components and use my existing 4 channel amp to power the rear speakers and bridge the other two channels to run the sub at 150watts???????????????
Old Mar 23, 2006 | 04:20 AM
LS1 RULZ's Avatar
Re: Which way is better
Get the large subwoofer amp. Then take the 4 channel amp and bridge it to 2 channels and run your front speakers off of it. If you feel you just have to have rear speakers run them off of the HU's power.
Old Mar 23, 2006 | 11:18 AM
wakebordr2006's Avatar
yup, i'd do exactly what ls1rulz said to do
Old Mar 23, 2006 | 11:40 AM
97FormulaWS-6's Avatar
I agree with LS1.
Or... if you want to be really trick, buy a large mono amp, and a large 4-ch, and run the components up front and a pair of mid-bass only's out back... :P that's what I run and love it. But do not put any highs behind u unless you're running a surround-sound processor.
Old Mar 23, 2006 | 12:00 PM
Whats a decent pair of mid basses? Also, im a little worried about dimming lights when my sub hits when i finally have both subs, what can I do, OTHER than getting a high output alternator?
Old Mar 23, 2006 | 01:52 PM
LS1 RULZ's Avatar
Save your money till you can afford an alternator. Anything else and you're just pissin in the wind.
Old Mar 25, 2006 | 04:04 AM
95LT1conv's Avatar
install a capacitor before your power distribution block
Old Mar 25, 2006 | 05:58 AM
LS1 RULZ's Avatar
If you really think a cap is what you need then place it as close to the subwoofer amp, not the D-block, as possible. The subwoofer amp is what draws the most current so that's where the cap will do the most (if any) good.
Old Mar 25, 2006 | 02:01 PM
I dont have a distribution block, but i should probably get one right? Also, IF I got a capacitor, would one with a distribution block on top of it work?
Old Mar 25, 2006 | 04:55 PM
LS1 RULZ's Avatar
If it were up to me I would get a regular D-block. Then mount the cap as close to the power connections on the subwoofer amp as you can. This is where it will do the most (if any) good.
