Want a indash Dvd player using stock bose speakers
Old Oct 2, 2003 | 11:56 AM
ZDriver96's Avatar
I can buy that adapter right?
Anyone have a website where i can get the adapter to work with the bose impedence levels?
Old Oct 2, 2003 | 10:00 PM
Shawnster95Z28's Avatar
If you put a DVD in your car then the audio will be going through whatever head unit you have. Do you have the stock Bose head unit?? Or do you have an aftermarket unit intergraded with the Bose system??? If you have a aftermarket unit with auxillary inputs then you can run the audio through it. If you have the stock Bose unit then you may have to get a FM Modulator to run the audio to. When you get your audio to your head unit then it goes to your speakers like any other music or anything. There's several different options but that's about all I can tell you without knowing your situation or what kind of head unit you got.
Shawn
Old Oct 2, 2003 | 10:17 PM
firebirdude's Avatar
He said he wants an INDASH DVD player. I assume replacing the stock head unit. Even with the Bose system, no special adapters are required. Just your normal dash kit, wiring harness and antenna adapter.
Old Oct 3, 2003 | 10:12 AM
ZDriver96's Avatar
Yeah for the time being I want to just stick the indash dvd player in and leave the stock bose speakers to play the sound. So its just plug and play..
I know the bose speakers run on a different impedeance and thought I needed that PAC adapter...
Old Oct 3, 2003 | 12:00 PM
They do, but that only matters if your are replacing the stock speakers with aftermarket ones.
CamaroHeed
Mar 18, 2020 09:50 PM
Rod Bender
Jan 1, 2015 03:18 PM
liquidice220
Aug 10, 2002 10:59 AM
MJ_Z28
Aug 7, 2002 07:15 PM
CobraEatr
Jul 29, 2002 11:46 AM
