volume issue
Old Feb 25, 2007 | 10:22 PM
RKPsk8er's Avatar
volume issue
I have a playstation 2 hooked up in my car. The audio goes directly to my 2 amps. 1 for the door speakers, 1 for subs. The video signal is split between my 2 monitors.
The problem is that I have no way to control the volume of the audio going from the playstation to the amp. I need some sort of, in-line RCA volume control but I dont know if that sort of thing exists.
I thought about running the playstation to the headunit and controlling it with that volume control but my headunit doesn't have any aux inputs.
Any ideas? also I need ideas on relocated my PS2 to the front of my car because I have to hit the reset button everytime I send power to it/turn on my car and its all the way in the back behind the back seats so its kind of irritating.
thanks
Old Feb 26, 2007 | 05:27 AM
j1shotz88's Avatar
ps2
some amps have special volume controls that you can buy that hook into the amp. and about the ps2 i was about to do the same thing but decided to sell mine. there really isnt a good place to put it seats are to low the only thing i could think of is in the glove box but i dont you would have to do some custom work for that to work. if it even fit.
Old Feb 26, 2007 | 09:19 AM
PentaVolvo's Avatar
ideally u should run it through the headunit, but they do make volume controls that run in line on the rca's. im sure is you search ebay for like amp rca gain **** you should find somethin
Old Feb 27, 2007 | 12:57 PM
nervekiler's Avatar
is the volume too high or not high enough? they do make in line attenuators which sounds like what i woudl reccomend IF the volume is too high.
Old Feb 27, 2007 | 04:27 PM
RKPsk8er's Avatar
Yeah the volume is too high but I think I found a solution, I CAN run it through my head unit if I buy this http://www.crutchfield.com/S-A8Gu2dm...00&I=130CDRB10 I'll just have to take the single channel audio from the PS2 and split it
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
KYWes
Apr 15, 2015 05:48 AM
NJLT1SS
Sep 11, 2002 02:29 AM
redzed
Sep 4, 2002 06:22 PM
