upgrade to 791xv
Old May 11, 2004 | 06:16 AM
MJ_Z28's Avatar
upgrade to 791xv
good morning. i currently have a viper alarm system in the car...can't remember which. I just purchased a 791xv, but since i'm a cheap ****, I want to install it myself. How much of the old wirring do you think I can recycle? If any of you have installed this system, are there anythings I should be looking out for? any help would be much appreciated.
thx,
--mj
Old May 11, 2004 | 10:54 PM
Javelin3o4's Avatar
how old is the old viper alarm? do you know what model it is? if its not too old you maybe able to just plug the harness into the new brain. also is the old viper remote start? if you are adding remote start you will need to connect a tach wire, brake wire, neutral safety switch wire and hood pin switch. also you will need to bypass the VATS system for the remote start to work. that will require measuring the resistance in the chip in your key and wiring a resistor matching your key's "resistor value" to a relay and then wire it to the vats wire.
Old May 12, 2004 | 04:50 AM
MJ_Z28's Avatar
thanks for the info. the alarm is at least 3-4 years old. I can't remember the model number...I'm not going to be able to use the remote start feature...it's a manual trans...unless there's something I don't know about that...
thx,
--mj
Old May 12, 2004 | 03:25 PM
Javelin3o4's Avatar
there is ways to bypass the clutch for remote start, its just not recommended because if the car is left in gear and remote starts it could take off, one guy i know has remote start on his manual and he left it in gear and the car jumped forward and hit a parked car infront of him.
Old May 12, 2004 | 04:00 PM
MJ_Z28's Avatar
really? any ideas where i might find some info on how to do that??
thx,
--mj
13qtr
Oct 28, 2016 08:11 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
MDZ28
11
Sep 24, 2015 09:15 AM
Tarizza
3rd Gen / L98 Engine Tech
Sep 20, 2015 03:26 PM
97SSdude
Aug 21, 2015 09:36 AM
