Turn singal won't work
The front right daytime running light/signal doesn't work. It comes on when I activated the stock alarm. The light also comes on when the headlights are on. I have changed the bulb (x 4 bulbs), checked fuses, and cleaned the socket with QD electric cleaner. Is there anything else that I'm missing?
Re: Turn singal won't work
I am right there with you man. Mine works fine with the DRL's and the lights at night, however when I use my turn signal it either gets stuck as a green arrow or blinks. There is no rhyme or reason to why/when it does this. Any help for both of us would be great.
