Trouble with new deck and sub
Old Feb 19, 2006 | 03:59 AM
thegift's Avatar
I just brought a car and i tried to replace the deck that the previous owner had installed with mine, but when I change out the deck all the speakers work except the 10in sub. Ive hooked up all the necessary cables e.g. everything that was connect to the deck being replaced. What could be the problem? And how do I fix it?
Old Feb 19, 2006 | 06:43 AM
Angelis83LT's Avatar
Re: Trouble with new deck and sub
what deck do you have? that might help a little bit in determining what it is. I know My Pioneer by default has the Sub output off from the factory. Perhaps you just have to go through and set the head unit up properly in order to use the Sub output.
Old Feb 19, 2006 | 12:12 PM
thegift's Avatar
I have a Pioneer DEH-8600MP
Old Feb 19, 2006 | 01:34 PM
yea. chances are then the sub output is turned off. read your user's manual on how to turn it on. By default it is off
Old Feb 19, 2006 | 05:18 PM
thegift's Avatar
Nope, that didnt solve it, ive turned on the sub w. and connected the RCA cables and the sub is still not responding.
Old Feb 20, 2006 | 07:55 AM
and the amp has power to it and is on? (just covering all bases). If the channel is on and it is inputting into the amp which has power then it should work. unless there is something that is being missed somewhere...
Old Feb 21, 2006 | 09:10 AM
VTsullyman's Avatar
Yeah check your Turn On lead to your Amp. I know on my Pioneer there are three pre amp spots. One is for rear speakers one for front and one for Sub. Double check to make sure you connected the preamp to the right set. Turn off the unit and hold down the Audio Button ( i think its that in your model) Change thru that menu till you get to the pre amp output seetings. Make sure the pre amps are set to Sub. Make sure all connections from Amp to Sub are good. Check Amp Fuse. Are you sure all of your speakers are working? Fade to back and make sure they are working. Theres alot of stuff you can check but start easy and work your way up. Verify connections and HU settings. Go over what i said and if still isent working we can work from there.
Old Feb 24, 2006 | 12:28 PM
thegift's Avatar
I've figured out what may be the problem. The RCA cables are all hooked up correctly but there one cable connect to the amp from the original deck. I'm not an expert on car electronics so I have no idea as to what that cable could be.
Old Feb 24, 2006 | 05:37 PM
could it be a remote on/off?
Old Feb 24, 2006 | 07:04 PM
thegift's Avatar
ya it is
Ericksd
Jan 20, 2016 06:07 PM
ZXXVIII
Sep 1, 2015 10:13 PM
Schul365
Aug 22, 2015 10:00 AM
Aug 7, 2015 01:26 PM
surreybrad
Jul 5, 2015 10:36 PM
