sub box and woofer
Re: sub box and woofer
If it's LOUD thumping bass that you want then a Stealthbox isn't the answer. They just don't have enough internal volume for that kind of bass performance. If it's accurate bass reproduction that you're after then a single 10" with about 300W will do the job.
Having a sub that matches well to the enclosure is critical. I used to have a single JL 10W3 with 600W that performed OK. I switched to an Alpine Type-S sub and it totally out performed the JL sub. I've since switched to dual Type-S subs in twin SubThump Stealthboxes. I couldn't be happier with the setup.
alright, so what do you guys think i should do??? i want something sort of loud, not crazy, but good sound also??
do they make these stealth boxes for both sides from sub thump???
if i got with a single or dual, which sub, and amp would be the best??
i only have one opening tho, the other side has plastic over it??
My amp sits there anyway, so I went with the drivers side stealth.
Running an Alpine Type-R and feeding it about 400 watts. Sounds great!
Passenger Side Sub
did you cut that ls1 rulz???
