sub box and woofer
Old Jul 17, 2005 | 08:25 PM
cam25aro's Avatar
sub box and woofer
does any one have one of them MTX thunderform boxes with the thunder 4500 10" sub?? they fit flush in the Rear hatch area on driver side.....how do they sound??
Old Jul 18, 2005 | 02:35 AM
Austin96Formula's Avatar
Re: sub box and woofer
Well, I didn't have the MTX setup, but I had a JL box with a 10w3 (and at a different point in time a 10w0) and both sounded very good with 400 watts..
Old Jul 18, 2005 | 05:09 AM
Lower's Avatar
I recommend Subthump over anything else. But I'm thrilled with my box!
Old Jul 18, 2005 | 06:39 AM
LS1 RULZ's Avatar
If it's LOUD thumping bass that you want then a Stealthbox isn't the answer. They just don't have enough internal volume for that kind of bass performance. If it's accurate bass reproduction that you're after then a single 10" with about 300W will do the job.
Having a sub that matches well to the enclosure is critical. I used to have a single JL 10W3 with 600W that performed OK. I switched to an Alpine Type-S sub and it totally out performed the JL sub. I've since switched to dual Type-S subs in twin SubThump Stealthboxes. I couldn't be happier with the setup.
Old Jul 18, 2005 | 07:24 PM
cam25aro's Avatar
alright, so what do you guys think i should do??? i want something sort of loud, not crazy, but good sound also??
do they make these stealth boxes for both sides from sub thump???
if i got with a single or dual, which sub, and amp would be the best??
Old Jul 18, 2005 | 09:26 PM
LS1 RULZ's Avatar
Click my sig to see my car's setup.
Click the SubThump link or like above, click my sig.
There is no best. Decide what you want from your system. Then decide how much you're willing to pay for this system. Then shop around as much as possible. Speaker selection should be done by the person buying the speakers.
Old Jul 18, 2005 | 09:40 PM
cam25aro's Avatar
i went to that site, but i only seen that box for the driver side, or does it fit both sides?/
Old Jul 18, 2005 | 10:06 PM
johnnyb's Avatar
i do believe that they discountinued the box on the passenger side.
Old Jul 18, 2005 | 10:27 PM
LS1 RULZ's Avatar
Contact Steve anyway. He may still have a few.
Old Jul 19, 2005 | 01:22 AM
I donno. 400w on my 10w3 was more then enough bass for me. Of course, i'm about to put 2 12's on an orion xtr1000 pro. so who am i to talk.
Old Jul 19, 2005 | 07:50 PM
cam25aro's Avatar
i only have one opening tho, the other side has plastic over it??
Old Jul 20, 2005 | 01:59 AM
Lower's Avatar
Yes, for the passenger side box, some cutting is required on the plastic covering.
My amp sits there anyway, so I went with the drivers side stealth.
Running an Alpine Type-R and feeding it about 400 watts. Sounds great!
Old Jul 20, 2005 | 05:45 AM
LS1 RULZ's Avatar
That wasn't a problem for me.
Passenger Side Sub
Old Jul 20, 2005 | 03:43 PM
cam25aro's Avatar
did you cut that ls1 rulz???
Old Jul 20, 2005 | 04:31 PM
LS1 RULZ's Avatar
Sure did. I used layers of duct tape to mark where I wanted to cut. It took about 4 or 5 passes with a sharp utility knife to cut all the way thru the plastic.
