Stock Head-unit!!
Old Feb 28, 2007 | 12:09 AM
LastBreedLS1's Avatar
Stock Head-unit!!
those anyone know what i would need to get in order to use my stock monsoon system with a sub and amp. i saw it on another camaro 01, he had his factory unit but also a 10'' sub running through it. sounded great. also i need it for the tape player, because i run my satelite radio thru it.any tips thanx
Old Feb 28, 2007 | 12:50 AM
fredmr39's Avatar
You will simply need a line-level adapter that (few bucks from any shop) that will convert the speaker-level output of the head unit to the pre-amp (line-level) input needed by most amps.
You can also buy some amps with speaker-level inputs.
Old Mar 1, 2007 | 08:19 PM
sweet!! i will look into to that.any sound shop should carry these right? thanks!!
Old Mar 1, 2007 | 08:48 PM
fredmr39's Avatar
yes - should
Old Mar 1, 2007 | 09:45 PM
RKPsk8er's Avatar
Just look for an amp with a high-level input.. Unless you already have one.
Old Mar 1, 2007 | 10:20 PM
fredmr39's Avatar
speaker level and high level inputs are the same, so you may see one term or the other used in case that confused anyone..
You're much better off (IMO) with the line out converter and a good pair of RCA cables. This will allow you to tap into the signal at the back of the radio, and convert the signal to a low level or RCA output which will help to reject some of the noise that would be picked up between the stock radio and stock speaker. This will also allow for an easy hook up if you do decide to replace the factory HU.
HectorM52
Jul 30, 2017 11:46 AM
canbaufo
May 25, 2015 12:01 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
