Stereo guru's help quick
Old Jan 16, 2005 | 02:39 AM
cmking26's Avatar
I need an ac to dc power supply (Im putting a car cd player in my basement wall) its a Kenwood 50x4. How big of a power supply do I need 3 5 7 12 or 20 amp? Its only running the stereo no amps or anything else. Thanks in advance.
Old Jan 16, 2005 | 07:51 AM
LS1 RULZ's Avatar
Re: Stereo guru's help quick
What size is the HU's fuse? You would want to use a DC power supply that can AT LEAST provide that much current or more. Preferably more.
Old Jan 16, 2005 | 03:59 PM
cmking26's Avatar
Ok so if stereo has a 20 amp fuse then I need at least a 20 amp power supply. Is that right?
Old Jan 16, 2005 | 04:50 PM
LS1 RULZ's Avatar
Yes, if you try to use a power supply smaller than that the HU will cut out on you when you try to crank it up.
Old Jan 21, 2005 | 02:57 PM
cmking26's Avatar
Ok stereo has 10amp fuse so I ordered 12amp power supply. Last question: I would assume both the constant and switched power lines from stereo just connect to power supply together. Is this correct? Power supply has two screw connectors one for ground and one for power.
Old Jan 21, 2005 | 04:17 PM
LS1 RULZ's Avatar
Yes, that is the correct connection. If you want to retain your station presets you'll need to leave the power supply ON all the time.
68camaroboltz
Oct 5, 2015 11:56 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
Greg88
Sep 20, 2015 07:14 PM
NewsBot
Sep 14, 2015 09:20 AM
Bxlt1
Sep 10, 2015 08:16 AM
