speaker problem
Old Aug 26, 2009 | 09:39 PM
Ocala93TA's Avatar
speaker problem
ok heres my problem i have two jl comp. 10s a kicker 800 watt amp and a jvc head unit . the problem when i turn up the volume past 10 the speakers cut out ? i switched the amp to another and checked all my connections any suggestions would be great thanks
Old Aug 27, 2009 | 03:55 PM
sabedra211's Avatar
The speakers or the subs. Every Amp has subs to match the ohms. you need to wire your subs together to make it 4ohms cuz thats what your amp is probably going to like. Also make sure you have it properly adjusted. And the wiring. I would probably recommend a high quality 8guage or 4guage wire any skinnier would probably not be good. When you switched the amp did it do the same? maybe one of the subs are no good. Try playing one sub see if it cuts off.
Old Aug 29, 2009 | 08:26 PM
Ocala93TA's Avatar
i will try what you mentioned about the wires thats really the only thingi havent tried thanks for the help
Rod Bender
Jan 1, 2015 03:18 PM
MJ_Z28
Aug 8, 2002 09:07 PM
BOOGER
Jul 25, 2002 02:42 PM
Chrisdude
Jul 24, 2002 02:25 PM
