Some more convertible questions
Old May 14, 2004 | 12:12 AM
Zedzag's Avatar
I have a 95 vert and need a little help. I have a small 6" powered bazooka tube and was wondering where I can get a remote source from. I don't think the verts have external factory amps do they? If so I have no clue where it is. Also I have a small 40watt amp and was wondering if it would be too much for the factory bose speakers. The amp is old BTW and it doesn't use RCA inputs but it uses speaker inputs(I know, it's ****) Are the factory bose speakers just running off the factory deck power?
Old May 19, 2004 | 04:21 AM
D James's Avatar
In the fuse block next to the door on the dashboard is a 12 volt source that will turn off when the power is turned off. This is where I hoked my amp remote 12 volt source to. Its kind of a spare port for such things. Just go buy the wire plug that goes on it. Very easy. Not sure about your other question.
Old May 21, 2004 | 01:37 AM
Zedzag's Avatar
Thanks, I tapped into that wire at the radio itself.
The amp idea was just that, an idea which won't work very well.
ChrisFrez
Feb 15, 2015 07:49 AM
rwferguson43026
Feb 6, 2015 10:06 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
86ZZ4
Aug 22, 2002 08:50 AM
Geoff Chadwick
Jul 31, 2002 12:07 PM
