Should I wire my jl 12w6's to make them 6 ohm or 1.5 ohm
You will need to use a series/parallel config for the subs. Follow this link, then click on the "Wiring your DVC subs" or something like that. On the next page, click on Two DVC subs series/parallel. That will scroll you down to the diagram.
To bridge on amp, you just use the positive from one channel and the negative from the other.
