safe to drill??
safe to drill??
hey, i just got my 95 z28 a few weeks ago and im starting to put in my new stereo. I build my sub box and my amp rack already and want to mount it. I need to put the amps right behind the rear seatand was wondering how to fasten it. i dont want to drill into the gas tank or anything.. so i was thinking about using 1/2" self drilling screws to fasten everything down with. Would this be safe to use without hitting anything? thanks a lot!
I'd be REAL careful that you watch where you drill. As you get towards the bottom of the hump, there is more room, but at the top, there is less than 1/4" room between that hump and the gas tank, and I wouldnt want to drill into the tank!
hmm.. good idea about the amps but i auctually have to mount my box right at the top of the hump, right before it drops down. there is really no other place i can mount it because of the design of it. Is it safe to drill near the outer edges of the hump? i might be able to get away with doing it like that if its safe to do it that way.. thanks for the reply's right before i was about to drill i realized the gas tank was under there so i decided to ask first.. well thanks a lot guys!
Check 3-4 times, drill once. There have been 3 tanks hit in the past 2 months at work. Most recent and most expensive was a 01 Benz CLK 430.
After I replied to this post, I checked another board, some guy asked the same question, cause his tank was hit by his installer.
maybe i will use my dremel tool with the cutting attachment which allows me to limit the depth of the cut. This way i can drill an 1/8" deep hole and see if i can put a screw into it or not. I think this will be my best bet.. any ideas?
Jul 10, 2015 02:23 PM
