Running the POWER to the brain
Old Sep 30, 2002 | 06:01 PM
ibanez6rg's Avatar
Right now my power cable goes down through the engine compartment following the exhaust pipe, going every which way under my car and to the spare tire location and up through the seal. I know, wtf??
My question is how do you get the wire on the inside?
I know you have to take the computer out in the engine bay and run it through the seal on the firewall, now how do you get to that area from the inside?? What dash pieces do you have to take off in order to get to it??
Thanks for any help
Old Sep 30, 2002 | 08:42 PM
97FormulaWS-6's Avatar
Well, on my firebird I need to take off the top kickpanel on the PS side obviously, the panel that's directly below the glovebox. To really run any wires you're also going to have to take off the kickpanel/rocker trim piece too. Really easy stuff, 4 screws, 1 metal clip, and 2 plastic pins, and both panels are off.
mike
Old Sep 30, 2002 | 09:35 PM
ibanez6rg's Avatar
Thanks for the reply, too late to work on it now...so I'll see where this gets me tomorrow or whenever I have free time!
Old Sep 30, 2002 | 09:54 PM
PaulN64's Avatar
look under your hood in back passenger side of the engine bay. You'll see the PCM. Take the two 10 mm bolts off and pull the PCM out of the way. Behind there on the firewall, you'll see a grommet. Move it out of the way and you'll have access to the inside of the car. Follow the other dude's instructions to run the wire.
Old Oct 1, 2002 | 07:46 PM
ibanez6rg's Avatar
Well I re-ran my power cable with no problem...BUT NOW MY CAR WON'T START!!! It started twice for a sec then died and the third time the motor just turned over and it won't start
AHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH
Old Oct 1, 2002 | 08:28 PM
PaulN64's Avatar
did you ran it through they way I explained it? if you did, make sure you didn't pull any wires on the PCM. Also, is it trying to turn over or trying to start like it's a dead battery?
Old Oct 2, 2002 | 10:40 AM
ibanez6rg's Avatar
It was turning over trying to start, the battery was ok. Well this morning I got in the car and started it again and it died after a second, then I tried it again and it started and ran. Wouldn't idle very well for the first 15 minutes of driving it and doesn't seem like it has a lot of power. WTF??
Old Oct 2, 2002 | 12:51 PM
PaulN64's Avatar
no SES lights? Did you check the PCM again?
Old Oct 2, 2002 | 08:16 PM
ibanez6rg's Avatar
No SES light and I didn't check the PCM...its seems to be running fine no with no problems and its idles right, I just wanna know what the hell happened. I'm thinkin' it had to be something electrical. Oh well
Old Oct 2, 2002 | 08:30 PM
PaulN64's Avatar
not sure what happened, but as long s your car works fine now
F'n1996Z28SS
Aug 23, 2023 11:19 PM
95chwagon
Feb 28, 2015 12:02 PM
XtremeLt1
Sep 13, 2002 08:50 PM
rs91
Aug 13, 2002 12:09 PM
