Remote wire
Old Apr 29, 2004 | 01:49 PM
Thor39's Avatar
Remote wire
My JL audio amp will not turn on when i have my remote wire hooked up but when i unplug it then its fine? my car has been down for two years with an engine rebuild and im just hookin it back up. the Alpine deck never came out and it worked when i parked my car. so all i have done is pluged the wires back in? Does any one have an idea what the problem could be?
thanks for any help
Dustin
Old Apr 29, 2004 | 03:27 PM
Tair's Avatar
Well there's only one way to find out.....Just get rid of that whole remote wire and run a new one to the cd player. That'll solve it. You'll probably also find out what the problem was along the way too.
Old Apr 29, 2004 | 03:32 PM
Rashiki's Avatar
How can your amp turn on without a remote wire?
Old May 9, 2004 | 02:02 PM
redsled's Avatar
simple! i am a jL audio dealer.... the jl amps are one of the few
amps on the market with the option of a remote wire. on the
side of the amp where the controls are there should be a switch
that says signal switching on or off. what this does, is that if
you do not run a remote wire it turns on when it recieves audio
signal from the rca's. i personally still would use the remote
wire and switch the signal sensing off.
warmeck
Mar 24, 2015 10:52 PM
Jeff1904
Jan 3, 2015 12:00 AM
themushine
Sep 3, 2002 10:02 AM
themushine
Sep 3, 2002 10:01 AM
Snake Slayer
Jul 29, 2002 12:39 PM
