Remote Starter install on a manual transmission
Old Oct 30, 2007 | 09:54 PM
lbrowne's Avatar
Is it possible to install a remote starter for an auto transmission on a stick shift if there is no neutral safety switch?
I know the possible implications and this is not for my TA but for my daily driver 240sx that never gets left in gear (I'm the only one who drives it). Looks like I can score a really good deal on a new unit, hence why I'm asking.
Old Oct 30, 2007 | 10:06 PM
bmnicolosi's Avatar
yes for a little safety hook the neutral safety switch to your parking brake, so it can only rs when e brake is up
Old Oct 30, 2007 | 10:26 PM
dbrown's Avatar
But it still is possible that you could forget and the button could accidently get pressed. I would not opt out of the neutral safety switch...
Old Oct 30, 2007 | 10:54 PM
lbrowne's Avatar
I don't think you understand when I say the car is never left in gear - trust me. But I could hook up a master switch so I can turn it off, my old explorer had that.
Old Oct 30, 2007 | 10:56 PM
lbrowne's Avatar
Actually, how do you mean?
So would the standard ProStart remote starter work for my manual then? It appears the manual version just has alot of extra stuff to not make the car start if it's in gear.
Old Nov 2, 2007 | 10:22 AM
PentaVolvo's Avatar
it will work fine just bypass clutch safety switch
Old Nov 2, 2007 | 03:46 PM
lbrowne's Avatar
My car doesn't require the clutch to start, it's been bypassed by a previous owner I guess.
Old Nov 8, 2007 | 10:35 AM
Chevyssoccer's Avatar
well if the car doesnt have a clutch safety switch, there is nothing to stop it from starting either with the key or a remote start device. So you have no problem other than the ever present possibility of your car driving away because for whatever reason the tranny was in gear. You only need to bypass the clutch switch if it works to begin with.
Old Nov 8, 2007 | 11:40 AM
lbrowne's Avatar
I have a on/off switch for the starter as well, in the event I have to park it in gear (which I never had to do yet) Also for the summer time I'll disable it.
I have a family of 5, that would be why I'm the only one who drives the car because the family doesn't fit in it. We have the jellybean for that. My car could just as easily slip out of gear and roll away somewhere if I parked it that way.
I'm going to see about wiring it so the car will only start if the handbrake is on.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
rocketman051894
Jan 30, 2015 03:23 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Jeff1904
Jan 3, 2015 12:00 AM
