relocating battery to the spare tire well
who has relocated their battery to the back of the car and what do I need to do it? Also, any kits which will have everything that I will need?
Just make sure that the battery you use doesn't vent gas when it is being charged. Otherwise you'll need to have a way for the gas to be vented out of the car. This is one case where I CAN recommend an Optima battery. They use a differenrt construction from your normal automotive battery and don't discharge any gas.
Originally posted by PaulN64
I'm using an Optima Yellow top.
I would also add that you should try to secure the battery. What I would do is make a carpeted board to go in the bottom of the spare tire area and make some brackets to bolt it to the antenna brace. Then you can set the battery on top and fasten it to the board. This would prevent the battery from rolling all around if you take a corner hard. JMO.
Good luck
If you plan on doing any drag racing you will need an external shut off with a rod that goes to the outside of the car. It needs to be a "push to off" type of setup. Search in either the drag racing forum or LT-1 Tech this has been discussed recently.
why would I need one? Is that a track safety requirement?
Here is a link discussing this topic.
Yes, it is a NHRA & IHRA rule along with having the battery in a sealed box that is vented to the outside because our cars don't have a rear firewall.
even with an Optima Yellow Top. That's what I'm using right now and thats' what I was going to relocated to the back
squarehead
Nov 21, 2014 08:02 PM
Wolf Warrior
Sep 12, 2002 07:34 AM
ZPLYR 19
Aug 22, 2002 01:44 PM
