Red Top vs Yellow Top Optima
Old Aug 8, 2003 | 02:09 PM
snakehunter's Avatar
Could I just settle with a red top instead of a yellowtop battery. This will be located in the trunk area ran in parallell with the other battery. I will be using it to run (2) Power 501 BD's and (1) Power 501X. I can get the red top at pep boys, I will have to order the yellow top.
Old Aug 9, 2003 | 01:09 PM
megabass's Avatar
Re: Red Top vs Yellow Top Optima
If you're planning on using it as a secondary battery for the stereo only, then I belive the yellow top would work better. Ture, he red top has more cca's for use as a starting battery, but not as much deep cycle capabilities as the yellow top.
I think the red top would work, but I also think the yellow top would be better. JMO
BTW, I use a yellow top as my only battery and no complaints
Old Aug 11, 2003 | 12:40 AM
CrAkD X 95TA's Avatar
they sell the yellow top at tweeter i think?
Old Aug 12, 2003 | 02:51 AM
limige's Avatar
doesn't matter, the yellow is an excellent battery.
but if you don't play your radio with the car off, or pull the battery out and let it sit then the red top will work fine.
you need the deep cycle if your gonna kill the battery and recharge it all the time, if it's constantly charged by your alt then it won't be a problem.
BUT....
you should replace the one up front as well or buy an isolater. if you don't then your front battery may drain from the rear battery when the car is off. by replacing both you generally don't have a problem.
guyomatic
Sep 11, 2002 02:11 AM
ur2slo50
Aug 30, 2002 10:45 PM
PaulN64
Aug 8, 2002 05:39 AM
PaulN64
Aug 7, 2002 06:17 PM
Carguy00
Aug 6, 2002 10:25 PM
