reciever installation
Old Jan 30, 2006 | 01:28 PM
new camaro owner's Avatar
why is that all the cd players on crutchfield say that the player will stick out of the dash about a half inch. Is there any way to fix that and make it flush when installing it or all aftermarket players too big for the camaro?
Old Jan 30, 2006 | 02:22 PM
JakeRobb's Avatar
Super Moderator
Re: reciever installation
In some cars, you can cut away whatever is at the back of the opening and fit a deeper deck. It worked in my Oldsmobile that way, and I was able to flush-mount a deck that was an inch too deep.
I haven't had the dash apart in the Camaro to tell you for sure, but in the case of my Olds, it was a matter of cutting off one small plastic tab and then just pushing some wires to the side.
Old Jan 30, 2006 | 07:35 PM
TransAmAbe's Avatar
If you don't bust off the plastic piece inside the dash, it will stick out. I busted mine off. It's a little plastic tab that has a hole in it to help align the OEM head unit. If you look at the picture of a GM F-body head unit there's a black plastic nubby thing sticking out. My aftermarket H/U sits flush since I busted off the little plastic tab in the back of the dash.
Abe
Old Jan 30, 2006 | 07:45 PM
PentaVolvo's Avatar
X2 Bust that plastic tab off in the back and it will sit flush, even with tab off you can put stock unit back in if need be at a later time it will install just fine
Nov 18, 2023 07:21 PM
Victor Lamb
Aug 26, 2017 02:52 PM
Richardan15
May 30, 2015 08:36 AM
1996LT1Z28
Apr 14, 2015 07:15 PM
Carogna'sZ-28
Feb 3, 2015 07:04 PM
