rear speaker wires
Old Oct 18, 2010 | 03:53 PM
LLYONS92's Avatar
rear speaker wires
i just bought this car and i cant figure out what wires in the rear are needed to hook up aftermarket speakers. i looked at the manual but there are many same color wires. a pic would do wonders please help
Old Oct 22, 2010 | 08:26 PM
Chevyssoccer's Avatar
so would knowing what car you are talking about.
Old Nov 3, 2010 | 07:04 PM
Lilatlboy6969's Avatar
Re: rear speaker wires
if your wiring a 93-95 cant remember if 96 and up have the bose or not but its a 5 speaker system.
every speaker in that car is pre amp'd from the factory trust me i know this i just re wire'd my entire aftermarker system and had to bypass all the stock amps because well for pg-13 sakes pieces of trash. but if u want to bypass these amps youll have to start speaker wire from a aftermarket radio all the way to the speakers there's no way to use the stock wiring as it is all hooked to the amps and i dont believe u wanna go messing witht he harnesses as its not worth the trouble.
just unplug the stock speakers run your own wires from the radio to them and you'll be good, i tried to cut n splice into the old wires and even when u do it sounds like trash cuz its all setup for the stock bose system and there's no way to tune the stock amps
i hope i helped ya pm me if u need anymore help i've been working on my system in my 95z for almost a year now and i have installed amps, tweeters, and rewired the entire radio system using none of the stock wires execpt the main harness to power the radio, i've been through it all with the radio in this car
Old Nov 20, 2010 | 10:26 PM
ray396's Avatar
Cool Re: rear speaker wires
Hi, I am thinking about doing the same thing, Are you glad you did, sound quality? Ray
Evilfrog
Aug 7, 2002 11:36 PM
DarkHorse
Aug 1, 2002 04:59 PM
chewy41
Jul 28, 2002 11:20 PM
Anderson
Jul 28, 2002 10:57 AM
MissedShift
Jul 24, 2002 01:37 PM
