RCA cable??
Old Dec 10, 2007 | 07:05 PM
P's Avatar
P
Question RCA cable??
I went to Best Buy today and just picked up some generic type RCA cable (12') to hook up the Sub-W output for my Alpine CDA-7894 unit. I got it all plugged in and now the sub is not near as loud as it used to be. It also sounds like it is getting full sound ie: when I stick my ear up to it I can hear the mids and highs.
This is the type of cable I bought, can you buy a wrong type???
P
Old Dec 10, 2007 | 08:10 PM
96 Z 28's Avatar
sounds more like you have the amp set to full spectrum or high pass
I've used all different types of RCAs and never had any issue
Old Dec 10, 2007 | 09:17 PM
P's Avatar
P
Ok, just wanted to rule out the cables being at fault.
Old Dec 11, 2007 | 12:17 PM
valter's Avatar
Double check that amp LP filter is on, it is somewhere around 35Hz-100Hz depending on your setup. And... set the gains properly with a multimeter.
Old Dec 14, 2007 | 11:43 AM
lilchrisgangsta's Avatar
I recently put a system in my Z and had the same problem with the RCA's. My Subs wouldnt hit at all. But I guess one of the wires was fried, so maybe look over all your wires and make sure everythings working and connected. I had to re-wire the whole car, and it sucks!
Old Dec 19, 2007 | 08:54 AM
KEN96Z's Avatar
decent RCA's can make a difference but they can get allot more expensive, I can hear a difference between cheap kind and Monster Cable brand, the sound will be cleaner and the bass better sounding and more responsive. In your case it sounds like you have an incorrect (for your application) crossover setting on the amp, you might check to see if your cd player has a sub preout with crossover control from the head unit, but in any case if your amp is set to LPF then you should be ok.
G-BODYT56
Jan 14, 2022 11:14 PM
Novo
Jun 14, 2016 02:58 AM
93 RedBird
Nov 15, 2015 08:24 AM
marlar98
Sep 19, 2015 07:53 AM
AtlasXVIII
Aug 24, 2015 11:41 PM
