Radio Question
Old Oct 20, 2006 | 03:04 PM
GMCAMARO's Avatar
Radio Question
I have a 99, Camaro with a moonson, radio cd player. Verything is working fine. I am trying to determin what the code is before there is a problem. Yes I have googled it and searched here, I know the procedure for when it is locked out, but not for determing the code before hand. Anyonen know the answer to finding the code?
Old Oct 21, 2006 | 10:01 AM
LS1 RULZ's Avatar
Re: Radio Question
There is no code unless you enter one. If a code has been entered by a previous owner and you don't know what it is...
1. Press and hold presets 2 & 3 for about 10 seconds until the first 3 digits of the display code are displayed
2. Write the numbers down.
3. Press the AM FM button, write down the next 3 numbers
4. Call 1-800-537-5140, when asked, enter 202107, press the ÒbuttonÓ and enter the 6 digit code from the radio, you will get an unlock code, write it down.
5. Go back to the car, press the HR button and set the first 2 numbers, then press minute button and set the next two last numbers, press AM FM button, SEC should be displayed, turn on radio To remove customers code, repeat step 5. you should see --- on radio face, the code is now out of the radio.
Old Oct 22, 2006 | 07:53 AM
GMCAMARO's Avatar
Re: Radio Question
I have owned the car since new. In other words I should be able to remove the battery and not have any radio issue.
Old Oct 22, 2006 | 08:42 AM
LS1 RULZ's Avatar
Re: Radio Question
Yep, that's what I said.
ChrisFrez
Mar 22, 2015 07:00 PM
ChrisFrez
Mar 8, 2015 01:22 PM
ChrisFrez
Mar 1, 2015 01:33 PM
ChrisFrez
Feb 22, 2015 08:47 AM
ChrisFrez
Feb 15, 2015 08:12 AM
