quick stereo Q's
Old Apr 19, 2003 | 06:51 PM
IROCBeerBeer's Avatar
quick stereo Q's
ok friend has a 97 z28 we are gonna hook up a amp and subs. i want him to use the stock deck instead of his jensen one. we have the RCA's that plug into the rear speaker wire, at least thats where i think they go? and then for the remote wire, can i just wire that straight into the power for the head unit it's self
Old Apr 20, 2003 | 02:05 PM
slayer6x6's Avatar
yes you can use a line out converter to run rcas from your factory radio, but in my experience you will get better sound from an aftermarket deck. as for the remote wire you cand find it by using a test light. just find the wire that gets 12V with the key in the on postiton. im pretty sure the yellow wire is the 12V ignition wire, and the orange wire is constant 12V. dont kill me if its not hope this helps!
Old Apr 20, 2003 | 04:30 PM
NineSevenWS6's Avatar
Correct. You can use the orange, just be sure to put a switch on the remote lead then. With the radio off, the amp will still be on, and will cause nasty feedback.
You can also use the pink (power antenna) wire if you have it.
Old Apr 21, 2003 | 12:56 AM
PaulN64's Avatar
that may or may not work. When I use to work for an audio shop, when we tried that lead, it didn't work. We would get voltage when the radio turned on but for some reason it wouldn't turn the amp on.
Old Apr 21, 2003 | 01:16 AM
Are you talking the pink wire? I know T/A's have the power antenna, and camaros dont. Maybe the radio in the Camaro's doesnt energize the power antenna wire, cause it obviously doesnt have one. Thats why I was unsure.
Old Apr 21, 2003 | 01:18 AM
Doh, you said it got voltage. How much? If it was anything 12.5 and over it should have definatly kicked the amp on.
Old Apr 21, 2003 | 01:23 AM
PaulN64's Avatar
We just used a test light so can't really say.
68camaroboltz
Oct 5, 2015 11:56 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
Greg88
Sep 20, 2015 07:14 PM
NewsBot
Sep 14, 2015 09:20 AM
Bxlt1
Sep 10, 2015 08:16 AM
