Putting together a little bit o' bass, help please..
Old Nov 10, 2003 | 11:25 PM
KyleBlue85Iroc-Z's Avatar
Ok, I work at Circuit City and get some darn good discounts on audio equipment. I've decided I want to put a stealth box in my Z and just give it a little extra kick, nothin special. I'm not an audio expert and I don't care much about hitting SPL (is it SPL??) levels, just listening to my cd's. So far here's what I'm planning on getting. Let me know what you think.
Stock Bose system running through a preout converter(yeah, I know, but still I'm not getting a new HU), MTX Thunder 421D (300Wrms @ 2 ohms at 12.5 VDC), Infinity Perfect 10.1d (dual voice, 350Wrms max) and the MTX stealth thunderform (0.6 cubic feet, the Perfect sub is made for this space). I could possibly go up to the Infinity Perfect DVQ, but I'm thinking that's a little overkill.
Let me know what you guys think about this setup. I'm not open to other brands, this is a do or not do type thing with these components only.
Thanks for any help,
Kyle
Old Nov 11, 2003 | 01:43 AM
Actually, now that I was thinking about it, I could also go with an MTX thunder 6 or 8000 10" if that would be a better route than the Infinity. I can pretty much get anything from MTX and Infinity at great prices, so those are the main brands I'm sticking to. I feasibly could also get Alpine (type R or S) or Polk (which I won't) or even Sony or Bazooka, but yeah on that.
Thanks again in advance,
Kyle
Old Nov 11, 2003 | 06:08 PM
CrAkD X 95TA's Avatar
id say get the alpine type R but i dont think itll fit in a driver side stealth....so maybe MTX is the best bet.
Old Nov 11, 2003 | 07:16 PM
So what do you other guys think? MTX sub better than an Infinity perfect? I was doubting they were, but maybe.
Old Nov 11, 2003 | 08:45 PM
i had a pair of infiti perfects and i never liked them....ive never had mtx subs in my car but ive heard them and overall i think they sound better.
Old Nov 11, 2003 | 11:36 PM
cheezer's Avatar
I would suggest getting an empty JL audio stealthbox or a stealth box from www.subthump.com The MTX thunderfoams are just a harden plastic as where the JL is fiberglassed and the boxes off subthump.com are mdf. Ive seen alot of people blowing subs and having other problems due to plastic box flexing
Old Nov 12, 2003 | 12:08 AM
I highly doubt that with the small amount of bass i'm going to use that it's gonna make the plastic flex too much. I'd go with the JL in a heartbeat, but I don't have the money for that stuff.
I'm now just debating the sub. Should I go Infinity or MTX?
Thanks again,
Kyle
Old Nov 12, 2003 | 07:50 AM
http://cgi.ebay.com/ws/eBayISAPI.dll...category=50565
theres an empty JL stealth for $70 plus shipping i dont know how much u planned to spend on the MTX but figured that might help....
Old Nov 12, 2003 | 11:27 AM
firebirdude's Avatar
I vote Infinity
Old Nov 12, 2003 | 12:25 PM
cheezer's Avatar
That one on ebay is the Vantage stealth box it is plastic like the mtx boxes. The true fiberglass stealth boxes come loaded with a 10W3v2 for the f-bodys
Old Nov 13, 2003 | 02:08 AM
Yeah, that ebay item was strange from the start. He ended it early anyways cause it was either "lost or broken"!
Anyways, I think I'm just gonna stick with my original plan and get the Infinity sub. It's a little more expensive than the MTX, but I think it should give a better sound in the long run, cause I like the sound as much as I like the feel.
Thanks for the help guys. Feel free to comment more if you'd like, it's gonna be a week or two before I buy.
Kyle
Old Nov 13, 2003 | 02:00 PM
Tair's Avatar
Kyle, get the Perfect 10 and stealthbox, but get a better amp! Putting a sub in a smaller enclosure than recommended allows you to run more watts into the sub, because the setup is more inefficient in such a small enclosure. Perfect 10's have been found to run well in 1cuft boxes. The Perfect 12's run well in 1.4-1.5cuft boxes. (I used to spend all my time on a car audio forum in the past, and now I'm into speed) Good choice on the sub though, no need to get the higher line of Infinity Perfects. Let us know how it turns out!
Old Nov 13, 2003 | 04:31 PM
Ok, then amp: the next mono amp up from MTX is the 801D, which makes 500rms @ 12.5 VDC. Isn't that quite a bit overkill, even if the sub can take more power? AND, on crutchfield.com it says that the Infinity Perfect 10.1d goes in a non-ported box, size 0.6 cubic feet. Not to doubt you, just getting my facts straight.
Old Nov 13, 2003 | 06:27 PM
Tair's Avatar
Certain companies' speakers are able to handle much more than their rated power. (ex: my JL Audio 18 W3 handles 400watts according to JL Audio's website, yet I've been running 800-900watts to it for 3 years now with ABSOLUTELY no problems) Infinity Perfect 10's can easily take 350-400watts. I personally would go for the 500watts, but for you I'd suggest going along with exactly what you first planned. Since you're going through Circuit City, just return the amp and get the bigger one if it's not enough for you. Good luck and be sure to PM me if you need any help whatsoever about anything related to car audio!
Old Nov 13, 2003 | 06:50 PM
cheezer's Avatar
to add on what tair said the #1 reason for blown subwoofers is distortion not over powering
