problem with the monsoon system
Old Jul 26, 2009 | 03:53 PM
Drew24's Avatar
So i got my car about a year ago and its a 97 TA and it had a blown speaker so i decided to change out all the speakers and the cd deck and a amp and two ten inch subs. Oh yeah they are all after market. The speakers and sub are infinitis and the deck is a panosonic. Ever since i got them all put in for some odd reason if the music is up to loud all the speakers cut out except for the subs they still work just fine so i took back the deck thinking that was the problem and got a new one and it still happened. The only way that the music will turn back on is sometimes by throwing the car in nuetral and back in drive and if that doesnt work shuting it off and turning it back on the music turns right back on. Im thinking that the monsoon amp is being over loaded but im not sure can you please help im almost to the point of rewireing all of the speakers and taking the monsoon amp out.
Old Jul 28, 2009 | 09:19 AM
Chevyssoccer's Avatar
do it.
Old Aug 1, 2009 | 08:37 PM
Drew24's Avatar
Can I still use the stock wireing or should I just change all the wires and use new ones
Old Aug 2, 2009 | 07:34 AM
yeah its fine unless your gonna use a monster of an amp. just match the in and out for each speaker at the amp. The tweeters are not amplified in the monsoons
Old Aug 2, 2009 | 05:40 PM
Drew24's Avatar
Thanks are there any amps that you suggest that will fit in the same spot and will work with the six speakers
Old Aug 2, 2009 | 06:24 PM
my product knowlege is about 5 years old so youre on your own there. I just went with a 4 channel and left the hatch speakers on the head unit, but set it up the way you want.
Old Aug 3, 2009 | 03:05 PM
Drew24's Avatar
Thank you for your input i really appreciate it
Dimoncutr
Aug 18, 2002 09:39 PM
ChrisFrez
Aug 12, 2002 11:50 AM
30thZ286speed
Aug 3, 2002 04:54 AM
Brian-94TA
Jul 31, 2002 02:52 PM
'StangSlayer
Jul 25, 2002 04:13 PM
