power locks not working
Old May 15, 2004 | 07:28 PM
t-bucket's Avatar
the power door locks dont work , replaced the switch didnt help.. the doors are able to be locked manually, and with key. but the power lock switches for either side of car doesnt work... is there 2 different motors? or if one dies are they both disabled? any help would be appreciated, thanks.
Old Feb 23, 2006 | 12:02 AM
jaredmwright's Avatar
Re: power locks not working
I am having the same exact problem. Did you ever get it fixed?
Old Feb 23, 2006 | 12:14 PM
VTsullyman's Avatar
Check the fuse. Grab a volt meter and read the power on the lines.
Old Feb 23, 2006 | 12:19 PM
Thanks, I checked the fuse and it is fine. I will check the voltage at the driver side switch this weekend and probably replace both driver and passenger switches since they are so inexpensive.
Also, I have an aftermarket alarm I installed myself. Since this started, my alarm will unlock both doors fine, but will not lock them. I am leaning toward a bad driver switch.
Old Feb 24, 2006 | 12:15 AM
stroked383z28's Avatar
Typically the passenger side switch is the master switch in these cars depending on what year you have. So if the passenger switch is bad both switches will not work.
Roadie
Feb 16, 2015 10:34 AM
capebuf
Jan 13, 2015 07:22 PM
Rod Bender
Jan 3, 2015 03:15 PM
Jeff1904
Jan 3, 2015 12:00 AM
mr28
Nov 23, 2014 11:11 AM
