Power Converter - Have questions
Old Aug 21, 2007 | 08:00 PM
Need4Camaro's Avatar
I'm thinking of Installing an A/C D/C converter in my car, I have and constantly run a laptop when I'm pulled over and it's annoying to have to stop everytime to charge it up.
First question is, for a laptop - what kind and power rating converter would you recommend?
Second question is - I desire to hardwire it instead of constantly plugging it into a cigarette lighter... I wanted to run a small wire to a switch, which would activate a relay, which would activate the converter... is this recommended? or would I really need a relay? If so, what ratings would you select the relay at?
Old Aug 21, 2007 | 08:13 PM
bmnicolosi's Avatar
i would use atleast a 175 watt inverter. The inverter shoudl already have a switch on it to turn it on and off.
Old Aug 22, 2007 | 06:31 AM
Deja_vu_256's Avatar
if you really wanted to run a wire to so you cud turn it on and off from a switch... with most inverters(300w and up usually) you can take off a few screws to take off the plate with the on/off switch. cut the red wire so that you can attach your own 12v power source(be sure to put tape over the unused end of the wire so it doesnt short). you cud run the wire right from your fuse box. you cud run a wire from your acc. so that it wont go on with out your acc. on. if you wanted you cud use the rem. wire from your cd player so that the inverter cud only be on when your cd player is. wutever your power souce, run that to your toggle switch and then to the red wire going into the on/off switch on the inverter. u will need to keep the switch on the inverter kept on for your toggle switch to work. there will be plenty of vent holes that you can run the wire through on the inverter so you can re-assemble it completly only a little power is needed for the wire because it is only to turn on the relay in the inverter. i don't know if you wanted to go through that much work but it did it on all three of my inverters... it was pretty easy and if you ever wanted to use the inverter else where you can simple re-conect the red wires again and no harm done.... you wudn't need that much power for a labtop, but i you wanted a little extra power for other things, the best deal i found- watts per dollar - was 750w at walmart - i cant rember - mabey $50?
marineengineer
Feb 9, 2015 03:59 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
thenewkid
Nov 27, 2014 09:41 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
Geoff Chadwick
Jul 31, 2002 12:07 PM
