Power Antenna lead on 1994 TA Delco CD Player?
I was removing a GM Delco tape deck from my 94 Trans Am to put the factory Delco CD Player back in it, and a wire came loose from the connector that goes to my power antenna.
It appears that the tape deck is a 95+ Delco tape deck that has the auxiliary plug to hook up to a CD changer. The power antenna is a factory GM antenna, but did not come on the car from the factory.
What pin on the wiring harness does the loose lead plug in to? Does the 1994 Pontiac Delco CD head unit even support a power antenna?
Thanks,
-Shawn
Thanks,
-Shawn
The best thing I can tell you is to look into the end of the plug that the wires go in and see if you can tell which pin might have been crimped.
Or you can take a look at the matching wiring harness at an install shop and match up the plugs to see where the antenna pin goes.
Originally posted by NineSevenWS6
I was wrong.
I had an old harness in my room, some of the pins were wrong. I beleive its the 3rd one in. Next to the orange and yellow. Best bet it to check with a meter anyway.
I was wrong.
DING DING DING
We have a winna!
It was the 3rd wire in beside the orange and yellow ones.
-Shawn
BLUESMAN
Aug 26, 2002 06:07 AM
