Power Antenna Camaro and Firebird Interchangable?
I am looking to install a power antenna on my 02 Camaro but wanted to know if the power antenna from the Firebird (10482860) is the same as the camaro (10482859) power antenna, it's for a convertible.
i put a power one on my first 99 z and my current one, they just didnt come with them. The gm one {used in the t/a} works fine, or an aftermarket one will work also, just need to run a turn on, as the camaro's dont have one.
Just finished the power antenna install. I followed a couple How-To's found here and on the web. The things I did a little different were sodering the connector to the wire before inserting it into the radio connector. I also covered the wire from the radio to the antenna with 1/8" loom. This will protect the wire. I grounded the antenna to a nut holding the bumper on. Any metal to metal ground will work. I also cut one of the Orange power wires to the factory amp and used a butt connector with heat shrink tubing. One end went to the connector and the other I connected both the antenna and the other end of the cut power lead.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
