Possible HID setup for 4703 (Trans Am)
Old Jun 5, 2005 | 01:30 PM
ChicagoTransAm's Avatar
Just wanted to let you know that I have decided to go full speed ahead with an HID conversion for the T/A WITHOUT using projectors.
Using Delphi ballasts with Phillips bulbs that I have modified to hopefully provide a good beam pattern in a stock 4703 housing. I removed the old bulb from the Sylvania sealed beam headlight with a torch and a razor blade (gives you access to a screw that simply pops the bulb itself loose). Then using a tapered drill bit, slowly made the hole large enough for the HID bulb to sit in.
While bench testing, I used a ball peen hammer to gently mod the housing in order to get the bulb 100% straight inside there. Then I used aluminum to create covers for the bulbs in sections that were causing glare due to the beam pattern in the lens. A little epoxy to glue it in and RTV around the edges.
Haven't gotten it wired in the car yet...but if the first one works, I will do a full write up on it with pictures. Total cost? about 330 bucks with everything.
Old Jun 6, 2005 | 12:15 AM
meangreen661's Avatar
Re: Possible HID setup for 4703 (Trans Am)
u think all of this would work on a lt1?
Old Jun 6, 2005 | 12:38 PM
Eh....not really since you have both beams in one lens. You "could" do it...but you would lose your brights
Old Jul 16, 2005 | 08:22 PM
96SilverRam's Avatar
I'm thinking if you use a Bi-Xenon H4 HID kit in a 4x6 aftermarket housing that accepts H4 you should be able to do a 93-97 T/A LT1. I would think the low beam / high beam would still work ?
Old Jul 16, 2005 | 08:31 PM
Not sure how well that would work with the beam pattern of aftermarket setups. Might be worth a try, but I'm happy with good low beams (they're brighter than my old highs)
Old Jul 16, 2005 | 08:53 PM
I'm tempted to try the H4 bi-xenon setup.
Fastbird93
Apr 9, 2016 07:01 PM
Gio93z
May 21, 2015 02:56 PM
99TransAmWS6
Mar 22, 2015 11:00 PM
CaRParts102
Dec 6, 2014 08:45 AM
