Plz help me on the wiring on this sub install!!!
Ok, right now I have some MB Quart 10's in my g/f's car, but come Tuesday I got her two 15's that I'm gonna replace the 10's with.
Ok, here's the amp she's using:
http://www.onlinecarstereo.com/carau....asp?sku=10721
Here's the subs that are going in it:
http://www.sfxaudio.com/products/dis...p?ProdId=30276
First, I know the amp is a 4 channel amp, but that's beside the point, it's what I'm using for this. So, since the subs are 4 ohms, and the amp is stable at 2 ohms in 2 channel, so from what I understand, I should wire the subs up in parallel mode? Cause what I've read is that if they're parallel, the resistance will be halfed, so they'll in reality be 2 ohms when wired up that way instead of series mode? (remember I know SQUAT about car audio)
Also, how should I wire up the amp? This stuff is already wired up w/ the two 10's, but I got that installed at Circuit City and I don't know what the guy did. I was planning on just cloning the way he wired it with the new subs, do you think that'd be ok?
If anyone might be able to do a quick wiring diagram w/ that amp and the subs that I should use I'd GREATLY appreciate it, or if you could tell me some stuff to do, etc. Or if I should just clone the current wiring.
Oh, and I don't even know exactly what "bridging" an amplifier means, lol. (as you can tell I've never messed w/ audio stuff) so if you say I should bridge this and that please make a quick diagram for me in paint or somethin
Or provide a good explanation.
Ok. That amp is 2 ohm stable, but only in stereo mode. As soon as you bridge two channels together, you are in mono mode and the amp is only 4 ohm stable. So the amp is 4 ohm stable in 2 channels. Follow me?
Since your woofers have a 4 ohm impedence, I suggest bridging two channels together for each woofer. Using all 4 channels total. Follow me? Bridging an amp is easy. Just use the negative from 1 channel and the positve from the second channel. Then run a little jumper wire from the remaining positive and negative terminals. Got it? If not, just lemme know.
Originally posted by RallyRedTexan
Simply put.
1 sub bridged on front
1 sub bridged on rear
That's about it.
Simply put.
That's about it.
CobraEatr
Jul 23, 2002 06:32 PM
Wilson
Jul 21, 2002 05:08 PM
