Parallel battery help
Old Mar 19, 2007 | 12:20 AM
trickster2k4's Avatar
I'm thinking about putting a second battery into the trunk of my 93 z. I've been told to do this I should justdo the following:
--Find a place to mount it with some space andair.
--Drill a hole in the body and sand the paint off for the ground.
--Hook the old power from my amp(4 gauge) to the new battery. So the two bateries are connected.
--Use the new battery.
Is there anything either wrong with these, or anything more? I dont want to do anything with this until I know for sure I will be doing the right thing. Any help would be appreciated. Thank You.
Old Mar 19, 2007 | 01:05 AM
fredmr39's Avatar
What are the power demands of your current system? Do you really need a second battery to handle it? -this is for when the car isn't running so you can wear one batt down...right???
Old Mar 19, 2007 | 05:28 AM
LS1 RULZ's Avatar
Don't forget to use a battery isolator.
Old Mar 19, 2007 | 08:53 AM
PentaVolvo's Avatar
i agree with Fred what do you have that demands a second battery. I have done some pretty intense fbody setups and never needed another battery
Old Mar 19, 2007 | 01:48 PM
valter's Avatar
x100 or very bad things, including fire can happen.
Old Mar 20, 2007 | 02:31 AM
The reason I think I will be needing a second battery is because I will be running 2 amp. One 1000 watt peak and 500 RMS, and one 2400 watt peak with 800 RMS. That will go along with the neon installed, My fog lights, and the 2 monitors I will be putting in. Would my stock alternator handle that?
Old Mar 20, 2007 | 12:26 PM
PentaVolvo's Avatar
I would do the big3, get a nice battery and see what happens id say you will be ok. The screens really dont draw alot of power, and your amps unlesss running fulltilt dont draw rediculous current. My buddy has 1200rms sub amp and 70x4 4 channel in his TA with stock alternator and a generic battery and no dimming at all and this is before the big 3 upgrade
Old Mar 20, 2007 | 12:32 PM
LS1 RULZ's Avatar
A second battery is only for extended listening when the engine is off. If the engine is running then ALL of the car's electrical needs are met by the car's charging system. Once the engine is running your battery (or batteries) become part of the load on the charging system just like the stereo system, fog lights, etc.
Old Mar 20, 2007 | 01:54 PM
fredmr39's Avatar
Exactly - ultimately a new alternator is always the best option -- but from what I have read higher output alternators don't usually make their power until higher RPM ranges, and you probably make more power at idle with your stock alternator (someone correct me here).
I would probably use a battery isolator instead of wiring the batteries in parallel also - if you really want them in parallel as one load though for whatever reason, buy 2 new batteries that are identical to one another in every way possible. --Either way though, if you want plan on killing the battery a lot with the car off, go with Optima's YELLOW top battery/any good deep cycle battery and skip the second battery.
Formula Steve
Sep 19, 2023 08:31 AM
68camaroboltz
Oct 5, 2015 01:46 PM
jackpawt883
Sep 10, 2015 08:53 PM
weedog
Aug 15, 2015 08:23 PM
