No dash/hvac lights. Replaced column dimmer switch
Ive owned it for a few years and the dimmer only had two settings, bright and off. So I knew it was wonky. The other night the dash, hvac lights never came on. 1993 TA. Fuse not blown. Everything seems to work fine otherwise. Brake lights and all. I searched and every post came up for the dimmer switch on the column. None for the actual dimmer dial control. So I installed a new oreillys one, and still no dash lights, but the BRIGHT side is i was able to adjust the bright switch to function again. Silver lining!
Does anyone have a part number for a new dimmer control?
**edit: Solved. Dimmer fuse was bad eventhough looked fine.
2QUIK6
Jun 24, 2007 10:24 AM
MadMaxz28
Jul 1, 2003 11:28 PM
