new head unit installed but no subwoofer sound
Old Jun 7, 2004 | 10:20 PM
Freestylin59's Avatar
ok, i just got my new head unit but there is absolutely no sound coming out of the stock subs. I had the monsoon system. Is there a wire that connects to the wiring harness that powers the amp or the subs?
Old Jun 7, 2004 | 11:34 PM
nothingeined's Avatar
Most wiring harness have wires for only four speakers. That is why your fronts and the rear hatch ones work.
Old Jun 8, 2004 | 10:26 PM
Javelin3o4's Avatar
you can try the premium sound interface box from install edge which you can get at bestbuy its like 40 bucks, otherwise i belive you would have to rewire all the speakers.
Old Jun 9, 2004 | 07:07 AM
can u explain what that does?
Old Jun 9, 2004 | 07:34 AM
LS1 RULZ's Avatar
To add an after-markey HU to the POS Monsoon system use one of these.
Old Jun 9, 2004 | 04:26 PM
valter's Avatar
I just installed new HU to Monsoon system and all working great. Just two different things - I made my own wiring harness for HU (factory one should be the same) and replaced rear dual-coil speakers with single coil Rockford Fosgates 6.5" (4 Ohm). Much more bass now. Replacing front's with Alpine's SPS170A (4 Ohm) made a great improvement over stock too
Old Jun 9, 2004 | 08:54 PM
Valter: Where did you find the Rockford's at? I looked everywhere for those 6 1/2 subs and they said they stopped making them.
Old Jun 10, 2004 | 10:42 AM
valter's Avatar
I can't find any RFP4406 too. Nowhere. I just decided to bite a bullet and went to a local store (to make it easy to return them) and picked up Rockford Fosgate T162C speakers. They are not subs, they are 2-way coaxial, but there build quality and strong woofer cone convinced me on trying them. And, they work pretty well as mid-bass subs! More bass then my stock ones, very good on all volume levels, so I am keeping them. Actually you can force them to sound crappy if you try it too loud, but on same sound level fronts are starting sounding crappy too, so it seems to be hitting Monsoon limits (and my ears limits) - but on this point I can't hear my LM exhaust with windows down. They are in my car for like 4 weeks, and I hope they will work fine much longer
Old Jun 10, 2004 | 11:30 AM
Thanks Valter. I think I will look into those at work since we can order RF stuff on big discount
Old Jun 12, 2004 | 07:20 AM
LWillmann's Avatar
I installed some HPC-2206's in my wife's car. Granted I unstalled all aftermarket equipment and run those speakers off a Punch 501X amp, but they're good speakers just the same!
Old Jun 19, 2004 | 03:08 PM
Ex67's Avatar
mmxpress.com/rock_subs.htm.........$58.99 each......i bought a couple thing's from them in the past with n/p's at all
Rod Bender
Jan 1, 2015 03:18 PM
Geoff Chadwick
Jul 31, 2002 12:07 PM
Snake Slayer
Jul 29, 2002 12:39 PM
95 Mystic TA
Jul 29, 2002 08:50 AM
gmeapush
Jul 29, 2002 08:17 AM
