New amp, use monsoon wiring?
Old Sep 26, 2003 | 06:16 PM
Aklaim's Avatar
question.....say I purchased a new amp for my car. Can I just take out the monsoon amp and put in the new amp and use the existin wiring from the monsoon system? My old Mr2 came with an amp and it was possible to just remove the factory amp, and replace it with a aftermarket amp with great success. I figure the monsoon amp has to have a 12v, ground and turn on wire, so in theory it works, but I'm just wondering if anybod has actually done this. It would alos help keep things hidden.
Old Sep 26, 2003 | 07:01 PM
Rogue Leader's Avatar
Go here:
http://www.houston-f-body.org/tech/monsoon/Firebird.htm
for a wiring diagram of the amp harness...
Theoretically you could do it and it would definitely work... however I havent seen the gauge of the wiring in there, and especially for a main power line on an aftermarket amp, I would want to use a heavier gauge wire than what is probably in there... Smilarly with speaker wire...
Old Sep 26, 2003 | 10:19 PM
firebirdude's Avatar
DO NOT use the stock wiring!!! The power is WAYYY too small. Unless.....you have a lot of fire insurance on your car. Running your own wire is not nearly as hard as you might think. Lemme know if you need any help.
Old Sep 26, 2003 | 11:56 PM
Aklaim's Avatar
Oh I know how to install an amp. I was just wondering if its something I can avoid doing because the wiring is already there. I guess not. Oh well.....good to know.
Brian-94TA
Jul 31, 2002 02:52 PM
Geoff Chadwick
Jul 31, 2002 12:07 PM
Mad_Ice
Jul 29, 2002 09:44 PM
BOOGER
Jul 25, 2002 02:42 PM
Zomie
Jul 21, 2002 08:03 PM
