Need help with wifes car.
Old Jun 7, 2006 | 07:22 AM
PoorMan's Avatar
Hi peoples.
My wife drives an 04 Vibe and the blower fan quit working all of a sudden. Worked coming home from work and the next morning it did not. This is what I have found out.
1. The blower fan works if connected directly to the battery.
2. The A/C fuse is good.
3. The A/C switch works as the A/C light on the A/C button comes on when you turn the switch on.
4. The compressor engages and disengages with the A/C switch also.
5. Their is no blower movement on any fan speed setting.
6. The blower has no movement with the heater on.
Any advice on what I can check would be of great help. I got to figure this out or my Wolf roll bar money is going to fix this.
JD
Old Jun 7, 2006 | 08:15 AM
JJEXP's Avatar
Re: Need help with wifes car.
maybe the relay for the blower?
Old Jun 7, 2006 | 09:22 AM
PoorMan's Avatar
Thank you. That was it. I have three unlabeled relays and I tapped on each one with a screwdriver and all of a sudden it started working again.
JD
AlaskaZ28
Jun 26, 2015 11:38 PM
timmy39120
May 2, 2015 05:12 PM
