NEED HELP:confused:
NEED HELP:confused:
When it comes to sterio's iam an idiot, i own a 1994 Camaro, with factory bose sub an two front speakers, yay three speakers!! but anyways the factory CD player doesnt work, an i had a really nice aftermarket deck laying around in the basement, so i decided to start putting that in, everything works but i dont get any sounds out of the speakers, ive been told you cannot do this.. is there a way to by-pass so the speakers will work or a module to need to buy? or do i need to go out an buy new speakers?
Re: NEED HELP:confused:
Not sure if your speakers are setup like mine were but my two door speakers had individual amps, and you can just bypass the amp and wire the speaker directly. Im sure the bose sub is the same. I do believe you can also find the remote wire for the amps and run a wire to the remote on your deck.
just hook up the blue wire coming from the deck to the blue remote turn on wire on the wiring harness adapter you used...
or if you cut the factory plug off (dumb idea) then you can simply wire it up to the pink wire which is the amp turn on.
if this doesnt work id suggest taking it to a professional
