Is it my amp or is it my woofer?
Old Jul 2, 2004 | 01:48 PM
TransAmGT's Avatar
Ok....well I got a Kenwood 800 watt amp and a JL audio 10W3 dual voice coil sub.
It's been working great since I put it in in December but all of a sudden the sub has been cutting in and out randomly...it does it when I hit bumps and it sometimes does it when I'm just sitting there...I don't know what to do...I ran new speaker wire and checked all my connections to no avail...sometimes it works and sometimes it doesn't. Today I took the sub out of the box and hook it up to the amp and worked fine then when I put it back in the box and hooked it up it worked fine...as I put it box back in place and cranked up my car the sub quit playing! The power light on my amp stays on when the sub quit playing...so I don't think it's the amp...could the speaker terminals go bad? I'm so sick and tire of messin with it I can't stand it anymore! The only thing I can think of is maybe the plug in the back of the speaker box is messed up....but I dunno....anyone else experienced anything like this before!?!
Old Jul 2, 2004 | 02:42 PM
LS1 RULZ's Avatar
Try jiggling the RCA connections on the amp to see if you can make it cut in and out.
Old Jul 2, 2004 | 03:10 PM
TransAmGT's Avatar
I tried...didn't do anything....could it be something behind the CD player causing it?
Old Jul 2, 2004 | 03:51 PM
N2OMARO's Avatar
probably a ground problem. Check your grounds.make sure there is no paint under the terminal on the body and make sure you used a big enough ground wire....at least 10 ga. no less.
Old Jul 2, 2004 | 04:14 PM
TransAmGT's Avatar
It's not a ground problem....the power to amp is staying on so I know it's not my power or ground wires.......plus I have 4 gauge
Old Jul 2, 2004 | 05:20 PM
TransAmGT's Avatar
I think I fixed it!! My remote wire at the CD player was loose and so far the problems hasn't come back...and hopefully it won't!! Thanks guys!
RUENUF
Mar 13, 2016 03:37 PM
HibachiZ28
Nov 6, 2015 12:53 AM
football4life
Oct 4, 2015 07:48 AM
secbase8
Parts Wanted
Sep 8, 2015 07:11 PM
Brian Demeter
Aug 21, 2002 02:07 PM
