MTX Audio and SLP CAI Sale
im selling this stuff because first off, i have a different car, i'm not into big stereos anymore
THERE IS NOTHING WRONG WITH ANY OF THE BELOW..
MTX Thunder 6000 12" Sub - $89.00
Frequency response 29-150 Hz
Power range 75-250 watts RMS
Peak power handling 500 watts
Sensitivity 87.2 dB
Top-mount depth 5-1/8"
MTX 500D Mono Amp - $250.00
Trunk box for 2 12" subs - $30
MTX 8302 2 Channel Amp - $200.00
Power 12.5 VDC Input
2 Ohm Load150 w x 2 Low Level
4 Ohm Load75 w x 2
Bridged 4 Ohm Load 300 w
Power 14.4 VDC
2 Ohm Load212 w x 2
4 Ohm Load120 w x 2
Bridged 4 Ohm Load425 w
Dimensions(with ISO Feet): 11.5" x 9.75" x 2.1" (29.2cm x 24.8cm x 5.3cm)
MTX 1000D Mono Amp - $400.00
Specifications
RMS Power 12.5 VDC Input
Low Level Input
Crossover(s)
Low Pass @ 40Hz-200Hz - Variable
Compression Circuitry
Thunder EQ
EBC2 Port
RCA Output Low Pass Only
2 Ohm Load 1000 w x 1
4 Ohm Load 500 w x 1
Dynamic Power 14.4 VDC
2 Ohm Load 1500 w x 1
4 Ohm Load 750 w x 1
Dimensions (with ISO Feet)
17.8" x 9.75" x 2.1"
45.3cm x 24.8cm x 5.3cm
2 - 15" MTX Thunder 8000 Subs - 200.00 Each
Sensitivity: 89.5 dB
RMS Power Range : 500 Watts
Peak Power Handling: 1000 Watts
Impedance: 4 Ohm
Low Frequency response: 24 Hz
Diameter: 15 Inch
Frequency response 24-150 Hz
Power range 125-500 watts RMS
Peak power handling 1000 watts
Sensitivity 89.5 dB
Top-mount depth 6-7/8"
SLP CAI - 100.00
93-97 camaro v6
Custom camaro box for 2 15" subs - 200.00
pics of box here
*Price does not include shipping
Sensitivity 87.2 dB
4 Ohm Load75 w x 2
Power 14.4 VDC
2 Ohm Load212 w x 2
4 Ohm Load120 w x 2
Specifications
Low Level Input
Crossover(s)
Thunder EQ
EBC2 Port
Impedance: 4 Ohm
Diameter: 15 Inch
Sensitivity 89.5 dB
SLP CAI - 100.00
93-97 camaro v6
pics of box here
