monsoon question
Old Oct 10, 2007 | 07:21 PM
99rsown's Avatar
monsoon question
My wife and I recently bought a 99 camaro v-6 5spd with t tops and the monsoon system. My question is just before installing my JVC head unit the factory amp quit working, and after installing the head unit it worked for a small while, then quit again. A friend of mine also has a 99 with the monsoon system and an Alpine head unit and has had the same problem. If anyone could give me some help as to what the problem might be and how to fix it. Also, I have read (and heard from other owners) that the monsoon system has 8 speakers, why can I only find 6? Any help greatly appreciated!!
Chris
99 RS
83 Z28
81 Cutty Supreme Brougham
Old Oct 11, 2007 | 07:53 PM
lastZ's Avatar
cant help ya with the amp problem....but the speakers i can
2 in the rear hatch
2 in the sail panel
1 in each door w/ tweeters attached off axis which monsoon calls 2 seperate speakers
Old Oct 15, 2007 | 08:59 PM
BandDirector Blk98ZM6's Avatar
The HU sends its signal to the Monsoon amp and the amp sends it to the speakers. If you don't bypass the Monsoon amp and wire the speakers directly to the new HU, then you're not fixing anything by replacing the HU if the problem is in the Monsoon amp.
Old Oct 20, 2007 | 07:31 PM
Forklift's Avatar
you would have to do some testing, make sure its getting power to the amp and that the remote turn-on is ok, make sure the grounds ok at the amp in the right rear panel in the hatch
97QuasarBlue3.8
Sep 15, 2002 06:56 PM
30thZ286speed
Aug 3, 2002 04:54 AM
Brian-94TA
Jul 31, 2002 02:52 PM
Geoff Chadwick
Jul 31, 2002 12:07 PM
Chrisdude
Jul 24, 2002 02:25 PM
