low down on Db Drags
Old Aug 14, 2003 | 05:27 PM
DrDUKE's Avatar
The local shop is having an informal show and shine and db drag.
I think i wana try to see how loud i can be.. I dont have anything special so......
anyway do you have to bring your own cd? Should i just down load a certain frequency and adjust the gain appropratly??
Old Aug 15, 2003 | 08:44 AM
LWillmann's Avatar
Usually at SPL shows the officials will have a disc you can borrow.
Play your system as little as possible for a while before, run the engine to make sure the battery is fully charged.
I'd recommend you start with a sweep, unless you know where your box peaks at. If you do know, then start a few Hz below and go in 1 Hz steps to a few Hz above with about 1 second or so of playing time on each step.
Aug 24, 2015 06:41 AM
alphaauto
Jul 26, 2015 04:40 PM
94Form
Jul 17, 2015 10:56 PM
Noct
Jul 14, 2015 01:18 AM
